F23A with D15 ECU?
I was checking to see which ECU My '94 Honda Accord has and I found the following:
37820-P08-A01
According to http://www.rywire.com/catalog/identi...r-ecu-a-6.html that would make my ECU from a D15 JDM Civic with VTEC.
I have a F23A Motor which was installed before I purchased the car and I was wondering if this ECU might be installed to activate VTEC? Advantages or disadvantages of this combination of motor and ECU?
37820-P08-A01
How does it run?
Other than the fact that the P08 is based on a 1.5L with a VTEC engagement @ 4800 RPM and a red line of 7200 RPM. Vs the F23's 2.3L and VTEC engagement @ 3200 RPM and the power band is lower than the JDM D15. The fuel and ignition maps may not work 100%.
That being said, as long as it isn't running really lean, no driveability issues and the CEL isn't on you could be OK.
My Accord runs great. No CEL, I feel like it has good torque, I can't hear VTEC engage like I could on my '95 Civic D16Y8. I drive 120 miles a day commute and average over 31MPG. I don't know how to determine if it is running lean.
