ARP b20 rod bolt question
Old Feb 16, 2013 | 11:08 PM
civic-one's Avatar
Default ARP b20 rod bolt question
Ive read that b18 and b20 share the same rod bolts. Which rod bolt will be better for a b20vtec setup? The ARP 208-6401 pro series or the high perfromance 8740 will do just fine. I also found out that these bolts wont fit aftermarket rods. If in case I run aftermarket rods what will be my best choice?
Old Feb 18, 2013 | 05:09 AM
kyden's Avatar
Default Re: ARP b20 rod bolt question
if you run aftermarket rods, they already have ARP bolts in them. (99% of the brands anyway)
Old Feb 18, 2013 | 12:50 PM
blackeg's Avatar
and if you are using these with oem rods, you need the 8mm replacement studs. they are the same ones used by ls engines and single cams.
Old Feb 18, 2013 | 02:25 PM
civic-one's Avatar
I was planning on keeping the stock rods for the meantime thus the reason why I asked which is better. Rods eill be replaced later on fown the line. Do you guys know which is the 8mm ones? Or do I need to contact Arp.
Old Feb 19, 2013 | 05:18 PM
1998GsRIntegra's Avatar
http://www.lightningmotorsports.com/...1/i-61501.aspx
Those are what you need. They are direct replacement of the factory bolts. Just make you get the rods re-sized after you have the new bolts pressed in.
blackccoupe
Sep 26, 2009 01:24 PM
bluestreak_1
Nov 20, 2006 01:16 PM
poorboy44
Feb 10, 2006 05:54 PM
CrX-To-Tha-Max-v2.0
Oct 28, 2004 03:59 PM
