LCA bushing question need help asap
Hey guys. I got a Hardrace bushing kit and they sent me the wrong rear trailing arm bushings. The two outer ones are ok the shock mount bushing is the same size as the outers. Im screwed!. Autozone sells the front lca shock mount bushing. My question is, is the front shock mount bushing the same as the rear shock mount bushing? I ask because Honda diagrams sorta show them being the same.
if not someone please suggest me what parts store may carry that item. I have a life changing job to start on Monday and I need to fix it.
Thank you!
Thank you!
I know but at this point anything will do. I called autozone and their system has no dia specs. And the odds of me finding an si at my local junkyard are none!
Well I'm going to a junkyard tomorrow. I'm hoping to just find an lca. I have a 91 si, is there any interchangeable lcas I can use?
RATEDR
Aug 28, 2002 07:31 AM
