Will these wheels fit?
Yes but stock CR-V wheel is only 6.5" or so, not 7.5".
Two wheels identical to each other apart from width will sit differently even though they have the same offset.
U should be fine your Inner Clearance:-19mm and Outer Position: would extend +19mm
My 18's used to be 18x9.5 +38. My inner clearance was: -27 and outer position was: +61
Whats hub size of the mazda wheels? Do u plan on lowering/raising your crv? Tire size is ok but if they are going bald u should get 215/45 .
