d16 thermostat
Old Feb 16, 2013 | 11:38 AM
excoupeb20jdm's Avatar
Default d16 thermostat
quick question if i change my thermostat on my 2000 lx do i have to bleed anythang?? also my car is stock the car has the regular d16 that came with the car..
Old Feb 16, 2013 | 11:41 AM
vartok's Avatar
Default Re: d16 thermostat
yes, any time the coolant system is opened, other than the radiator cap, you should bleed the air out of the system.
Old Feb 16, 2013 | 11:46 AM
wheres the value location at to bleed the air out of the system?? because i blend a b series one b4 but this one i cant find the value..
Old Feb 16, 2013 | 12:13 PM
grumblemarc's Avatar
The Grumpiest
^^^Get off your phone.
Check teh FAQs. The procedure on how to bleed air from the system is there.
Old Feb 16, 2013 | 12:17 PM
HondaPartsHero's Avatar
Technical Hero
There is no valve
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
Old Feb 16, 2013 | 12:42 PM
so bleeding the system is basically that??
Old Feb 16, 2013 | 12:43 PM
The Grumpiest
Yup.
its not like the bserises engines?? the bseries engine has a little value that u bleed the block..
Old Feb 16, 2013 | 12:44 PM
oh ok
mlee19841
Honda Civic (2001 - 2005)
May 1, 2015 03:26 PM
motegicivic
13
Jul 4, 2011 05:35 PM
mrfootball420
18
Sep 29, 2009 09:40 PM
732xghost
Aug 23, 2009 08:48 PM
twenty
Jul 15, 2005 12:47 PM
