FS: 96 silver civic EK hatch H22 boosted high hp build
I am selling my project after alot of work. Need to make room for the family!
Price: 12500 OBO
Engine mods:
H22 cylinder head, crower retainers, crower valve springs, o/s crower valves, work done by Laskey racing, crower adj cam gears.
H22 stroker block:
F20 crank, H22 CP pistons, H23 spec pauter rods
Block work by Laskey racing, Sleeves by Dan Benson
Motor build has ~3000 km on it with brand new clutch also (same mileage), built with all honda parts (new of course), new oil pump, water pump, timing belt, manual tensioner mod (new oem honda parts), balance shafts removed (laskey racing did this), and custom crank work by Dan Benson.
--RC 850 injectors, aeromotive FPR, Walbro 255lph pump, Hondata s300 engine management, MSD digital 6 ignition, PLX r500 wideband (interior usb panel for tuning), RC engineering 68mm throttle body, port/polished h22 intake mani (hondata manifold gasket), magnaflow 3 inch custom exhaust,
-- Comp engineering front end traction bar setup with cross beam and adjustable radius rods.
--Turbonetics T3/T4E (.57), Revhard FMIC, vortech BOV, Turbosmart 35mm wastegate, turbosmart dual stage manual boost controller (have boost solenoid for elect boost control)
--ACT pressure plate, ACT extreme 6 puck unsprung clutch, ACT extreme flywheel, Quaife torque biasing diff, custom axles
--KVR python 4 piston calipers (front), disc swap rear, cryoslot rotors, omni coilover suspension, susp tech front/rear sway bars, mugen strut tower bars front/rear
--Racing Hart evo 17 inch rims, BFG drag radials front, BFG rubber rear (with spare pair)
--CF front lip, CF hood, type r rear lip, type r rear spoiler
--momo steering wheel, momo shift **** with leather wrap (looks good, not cheezy at all)
--Recaro racing drivers seat, interior upholstery custom with factory seat bolsters, etc. Have bolstered factory drivers seat to replace racing seat included. No marks on drivers seat or the factory upholstery.
--Pioneer head unit, kenwood amp, 2x10inch subs, custom enclosure trunk, compustar alarm starter (2 way unit).
Contact me at dleedell@shaw.ca for any further info,
Serious enquiries only.
Located in Edmonton, Alberta
Price: 12500 OBO
Engine mods:
H22 stroker block:
drummer0940
Apr 6, 2014 12:02 PM
drummer0940
Canada (Sales)
Apr 6, 2014 12:00 PM
