Need advice changing rear motor mount 99 si
Old Feb 15, 2013 | 06:52 PM
Brandon H.'s Avatar
Default Need advice changing rear motor mount 99 si
I'm changing my rear motor mount this weekend, need advice. Would prefer not to crawl under the car if its possible. I looked at the service manual but didn't see a section on the rear motor mount. How is this usualy done?
I just changed my clutch, and this mount looks harder to do then that.
Old Feb 15, 2013 | 06:57 PM
Former User's Avatar
Default Re: Need advice changing rear motor mount 99 si
Why are you replacing it?
You will need to access the rear mount from under the car.
It's much easier than replacing the clutch because there's no need to drop the transmission. Just raise the engine with a jack.
Old Feb 15, 2013 | 07:01 PM
Brandon H.'s Avatar
The mount is shot, and there is a LOT of engine movement, 1 torque mount and the rear mount is shot. I bought new mounts and filled them. I baby the car. I can jack up the car and put it in gear and rock the motor back and forth a few inches spinning the tire.
Do I take the T bracket off? Or just the mount?
Old Feb 16, 2013 | 05:53 AM
94civiccupew/b7's Avatar
yes you have to pull the t bracket out of the way to get to the mount and replace it. not that bad at all. just a little annoying taking the 2 rear bolts out in the tight spacing back there, but be patient they'll come
Old Feb 16, 2013 | 06:31 PM
Cap'N Chronic's Avatar
Make sure to put a piece of plywood under the motor and the transmission and jack it up from that so you don't risk damaging your oil pan.
boostin4door
May 23, 2005 04:41 AM
h23 milano red
May 24, 2004 09:00 PM
CristalCleanCivic 97 EX
Aug 8, 2003 10:39 AM
Civichatch972
Dec 8, 2002 11:42 AM
