Clutch fluid black
Old Feb 15, 2013 | 03:37 AM
Axatax's Avatar
Default Clutch fluid black
I did my auto to manual swap approx. 4K miles (roughly 12 months) ago. I bled my brakes and (obviously) my clutch at the same time using a lab vacuum pump.
The brake fluid looks like it aged appropriately (slightly golden brown), but the fluid in the CMC reservoir looks almost black. I used Valvoline DOT 3/4 at the time (from Advance), and the caps on both reservoirs are tight and in good condition.
Anything to be concerned with? Clutch is otherwise functioning fine.
Old Feb 15, 2013 | 03:39 AM
Axatax's Avatar
Default Re: Clutch fluid black
Well, the picture makes the brake fluid look worse than the clutch....
If you see this in person, the brake fluid looks almost like EVOO, and the cluth fluid really does look black.
Old Feb 15, 2013 | 03:41 AM
jbpnoman's Avatar
I'm assuming you bought all the parts used, rather than brand new. It wouldn't surprise me if the previous owner of said parts didn't take care of them for ****, so the darkness you're seeing is probably just old residue. It's nothing to be concerned about, but it also wouldn't hurt to flush the system again with some fresh fluid.
Old Feb 15, 2013 | 03:43 AM
ameer_vtec99's Avatar
looks fine . do you have any brakes problems?
the clutch fluid looks fine nothing to concerned about .
Old Feb 15, 2013 | 03:55 AM
Axatax's Avatar
There is a mix of used and new parts:
- The CMC and slave cylinder are brand new Exedy parts (OEM equivilent).
- The hydraulic lines are 100% brand-new Honda OEM (bought from dealer).
- The CMC reservoir is used OEM, but was cleaned with brake cleaner.
(The transmission, shift linkage and shifter are used, but I don't think this is germane to the problem. Clutch, FW and pressure plate are also new Exedy OEM equivalent parts).
Old Feb 15, 2013 | 05:09 AM
JONESn''s Avatar
If its that big of a deal, just re bleed them. How much total fluid does that take roughly anyway?? not too much. Like others said though if no shift/pedal problems occur then your most likely good. But for piece of mind I would just keep bleeding till its clean.
Old Feb 15, 2013 | 06:33 AM
BryanM.'s Avatar
Resident Gearhead
I wouldn't be concerned. It can get much darker than that.
Old Feb 15, 2013 | 07:09 AM
dirty19's Avatar
Ridin Dirty in Cali
^^ agreed.. if it bothers you, siphon most of it out, and fill it then bleed the clutch till you dont see it anymore.
Old Feb 15, 2013 | 07:30 AM
Axatax's Avatar
Nah, it's no biggie. I just wanted to make sure it's not contaminated or overly oxidized.
The pictures are deceptive, as the clutch reservoir really does look inky black. One would think the brake fluid would age faster than the clutch, but reading up on this "problem" (if you call it that), it's apparently normal.
Old Feb 15, 2013 | 01:26 PM
Former User's Avatar
Just flush it until clean.
Old Feb 15, 2013 | 01:51 PM
94EG8's Avatar
Seagull Management
Don't worry about it, it's just rubber from the cup in the master cylinder that's turning the fluid black.
Old Feb 15, 2013 | 02:36 PM
Ryan96GSR's Avatar
+1
Bottle of Dot 3, a buddy and 10-15 minutes should take care of the merky fluid.
Old Feb 16, 2013 | 10:44 PM
strategy400's Avatar
Part of its job is to hold contaminants in suspension.
DOHCter VTEC
Dec 6, 2007 04:48 PM
99blackLS
Jan 13, 2007 10:23 AM
araknis
May 18, 2005 09:26 PM
B18Redline
Aug 18, 2003 10:56 AM
KF_S2000
Jul 21, 2002 01:41 PM
