Civic HARNESS Problems
Old Feb 15, 2013 | 12:55 AM
Rene1123's Avatar
Default Civic HARNESS Problems
1996 Honda Civic Hatchback
ok so I bought a completely stripped shell! I was able to find a complete interior for 200 dollars and it was a 99-00 hatchback floor harness. I have auto climate control.
I bought a d16y8 vtec motor came complete with p2p ecu. I read up that 96+ was the same however car is not starting.
My question is the engine harness would be the same no matter year right? any info or suggestions would be greatly appreciated.
If you need any more info please feel free to ask.
Old Feb 15, 2013 | 12:58 AM
Rene1123's Avatar
Default Re: Civic HARNESS Problems
OH! and btw two minor problems but maybe the cause there is three plugs coming out of the floor harness for the rear fuel pump only two are connected one is MIA completely coming from the car not the floor harness
ALSO! Check Engine Light does not turn on at all even when on position for key. NO LIGHT WHAT SO EVER.
Old Feb 15, 2013 | 01:05 AM
HondaPartsHero's Avatar
Technical Hero
96-98 and 99-00 harnesses differ. You can't combine 96-98 engine harness and 99-00 cabin harness and vice versa:
Old Feb 15, 2013 | 01:07 AM
Rene1123's Avatar
let me go double check!
Old Feb 15, 2013 | 01:10 AM
Technical Hero
You'll need to match up harnesses. If you're using a 99-00 dx cabin harness you'll need a 99-00 dx engine harness.
Rene1123's Avatar
Yes i have a 99-00 engine harness THANK GOD! thanks for the info
however I did find a brown plug! is that for the relay on the inside of the dash? or what else would it be?
any idea on the rear plug for fuel pump?
Old Feb 15, 2013 | 01:12 AM
Rene1123's Avatar
DAM! ok hondapartshero I beileve the motor is off a 99-00 Coupe EX d16y8 WITH Vtec
and the cabin harness is a 99-00 HATCH unsure of model :/ thats a no go?
Old Feb 15, 2013 | 01:14 AM
Technical Hero
Can you post some pics?
Old Feb 15, 2013 | 01:15 AM
Rene1123's Avatar
What exactly would you like? But yes I can
b20turbojason
Jun 8, 2009 04:30 PM
enigma94
Sep 29, 2007 05:42 PM
Timmay
Aug 15, 2005 03:59 PM
Blanket Jackson
Apr 23, 2004 07:23 AM
Silverbeast
May 14, 2003 11:07 AM
