Installed Dx oil pan on ex. L brackets?
So the dx pan has no holes for the L brackets. Did not having the brackets cause a problem for anyone? The ex pan looks like a better inner design, I hope I didn't make a bad choice...
Oh, and I'm hearing some rattling, is replacing the exhaust gaskets a must?
The stiffener brackets for the transmission? No you don't need them.
If you're talking aluminum vs steel pan on a '96 - '00 the steel pan is a better design, they don't crack and they don't normally end up with a stripped oil drain plug hole.
Thanks for the reply. I have a little bit of a rattle down there, are the gaskets a must to replace?
The one cracks and the other dents. I feel like there is an upside to either.
Dents don't leak. As long as you don't have a dent where the pickup is it wont matter.
You should have an exhaust manifold gasket between your manifold and your head, and a doughnut crush gasket between the manifold and cat/b-pipe.
Also, are you sure you have a DX pan? My DX has the bracket between the transmission and block running around the oil pan, but I don't know if there's a difference in the brackets.
milky way
Honda Civic (2001 - 2005)
13
Dec 14, 2014 05:59 PM
