Fluctuating idle gsr crx
Old Feb 14, 2013 | 10:51 PM
Rexcar69's Avatar
Default Fluctuating idle gsr crx
I drive a 1990 Crx hf gsr swapped. My car has a hard up and down idle. I've cleaned the iacv, fitv, and bled the coolant system. I started to think it was a vacuum leak, there's a vacuum line that comes off the top left of my stock gsr intake mani. When I hold my finger over one end the idle isn't as rough. Anyone know where this vacuum line goes? I have pics just don't know how to upload them. Any other possibilities that could be causing this? All help will be greatly appreciated thanks in advance
Old Feb 15, 2013 | 07:38 AM
grog's Avatar
Default Re: Fluctuating idle gsr crx
If that hose isn't connected to something it likely your issue.
When you say the hoses/line on the left, do you mean driver side or passenger side?
There are 4 vacuum lines to hook up to the intake manifold.
look here for routing:
http://site.hamotorsports.com/b18c1-vacuum-diagram
Do you still have the charcoal cannister? If you removed it you'll need to cap those lines off. look for some vacuum hose caps: http://shop.advanceautoparts.com/wcs...8_pri_detl.jpg
tgkaotic
Oct 3, 2012 09:21 PM
SiRCiviC94
May 13, 2012 10:05 AM
dustinbs144
Jun 18, 2011 09:37 AM
egmadness
Jun 7, 2006 09:34 AM
Spec R
Apr 8, 2004 10:26 AM
