Replaced PCV Valve....worst.
Old Feb 14, 2013 | 06:45 PM
jhuerto23's Avatar
Default Replaced PCV Valve....worst.
So I replaced my PCV valve on my CX motor because the idle was pretty rough, it was bouncing up and down and when it sat steady, it sat pretty low. So I figure I should replace the PCV valve. I got the part from Kragen and went ahead and replaced the old PCV valve. I did the shake test and only heard a few rattle compared to the new valve. It fixed the bouncing idle part but now it idles lower than before at a steady rate. What did I do wrong? I pushed the valve as hard as I can back in. Any suggestions?
thanks,
Jeff
Old Feb 14, 2013 | 06:58 PM
Emeraldbomber's Avatar
Default Re: Replaced PCV Valve....worst.
Have you cleaned your iacv and adjusted your idle?
Old Feb 14, 2013 | 07:15 PM
beecee18's Avatar
not sure about the cx PCV,
but confirm that the PCV is installed correctly (not backwards/reverse direction)
Old Feb 14, 2013 | 07:48 PM
jhuerto23's Avatar
Nope, I will do that this weekend.
thanks,
jeff
Will double check..
Old Feb 14, 2013 | 07:54 PM
report back
Old Feb 14, 2013 | 08:06 PM
jhuerto23's Avatar
report back
You got it, thanks for the suggestions.
Zaraki
Jun 22, 2013 08:57 PM
Praetor353
Apr 28, 2009 03:59 PM
HybridBB6
Jun 24, 2007 02:36 PM
justint
Jan 15, 2007 11:00 PM
redex94
Mar 22, 2005 10:28 AM
