Can I use a b18b1 head with obd0
My hatch has 91 LS swap in it (b18a1). I was replacing the the blown head gasket and inspecting the head, i noticed the cam journals on the exhust were mushroomed out, not a smooth mirror finsh. I took it to a machine shop and they told me it was too far gone, and oil starvation was to be blame for. So, after many trips to junkyards and no sucess. I gave up on bought a head from a speed shop. Another LS head. So, inspecting the head, it look good and I bought it. It also came with intake. But from what I found on google, it probley came from a newer b18b1. I was wondering If I could use the b18b1head and intake on my block. I was thinking of just putting the dizzy and hooking up the hoses and call it a day. but some hoses are located in different places.
for the dizzy use the obd0 unless your coverting it to obd1.
and for the intake manifold the map sensor is located on top of the throttle body.
Doesnt matter which map sensor you use, the one on the firewall or throttle body.
Also use your stock injectors if you using resistor box
hdacivic88
Jan 16, 2013 10:53 PM
JdelMsolG
Jul 27, 2008 05:51 PM
SaturdayNightWrist
32
Sep 11, 2006 06:03 PM
som1_2race
Apr 25, 2005 07:52 PM
BlingBlingCivic
Mar 8, 2005 11:27 PM
