Not firing on cyl No. 1
Old Feb 14, 2013 | 02:16 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Not firing on cyl No. 1
D16 with a fresh ITB install. Consistently not firing on number 1.
It gets fuel (I pointed the ITBs up and they all spray) and it gets spark, but the spark plug comes out soaked. Timing is set at 16.5.
Does that sound like flooding?
Old Feb 14, 2013 | 04:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: Not firing on cyl No. 1
Sounds like bad spark plug lead.94
Old Feb 14, 2013 | 05:33 PM
i'll check tomorrow.
Old Feb 14, 2013 | 05:55 PM
Crx_owner_20's Avatar
Compression in cylinder number 1 is? Cracked spark plug, bad wire...
Old Feb 14, 2013 | 05:57 PM
good compression on all cylinders, the wire is fine, the plug is fine
i am dubious on those reasons, the car ran perfect before the ITB install.
Old Feb 14, 2013 | 06:02 PM
hybridmiklo's Avatar
if the plug is good. then the injector is staying open
Old Feb 14, 2013 | 06:06 PM
it is possible it is leaking, but i have seen it open and close during cranking. i will be purchasing a wideband soon, and i will move the injector to a different cylinder to see if the dead hole moves with it
Old Feb 17, 2013 | 12:47 AM
Moved the injector from No. 1 to a different cylinder, dead hole moved with it.
Time for new injectors.
Old Feb 17, 2013 | 01:07 PM
Scott_Tucker's Avatar
How do you know the plug and the wire are good?
Old Feb 17, 2013 | 03:03 PM
fcm's Avatar
fcm
Old Fart
If he moved the injector, and the problem moved with the injector, the problem can only be the injector. 94
Old Feb 17, 2013 | 03:29 PM
I didn't see that. I think I left the browser window overnight. Agreed, it can only be the injector.
Old Feb 17, 2013 | 07:14 PM
i got a set of CBR1000RR ITBs on the way. 295cc injectors, 8 of them to choose from!
slowwcivic
May 25, 2011 06:18 AM
thunderboy
Apr 24, 2010 08:39 AM
B18CivicHatch
Aug 24, 2007 12:13 AM
themex77
Feb 17, 2007 02:29 PM
TurboTeG4
Sep 6, 2003 09:04 PM
