Ignition Timing and A/F ratio...
Old Feb 14, 2013 | 12:18 PM
video_voide's Avatar
Default Ignition Timing and A/F ratio...
Am I looking at this accurately?
TIMING:
D16Z6 stock ignition timing: 16BTDC
Advance the timing by tapping the distributor toward the firewall.
Retard the timing by moving it toward the front bumper.
The mark to the left of 16-BTDC is advanced at 18-BTDC.
The mark to the right of 16-BTDC is retarded at 14-BTDC.
____________________________________________
A/F:
Rich means more fuel than actually needed for a "clean" burn.
Stoich (stoichemetric) means a perfect mixture of air and fuel.
Lean means there is not enough fuel, and too much air is NOT being ignited.
Ignition timing (timing) and A/F ratio are two different things, however...
Retarding the ignition richens the A/F ratio.
Advancing the ignition leans the A/F ratio.
Clarification: the A/F ratio measured is not the atmosphere existing within the combustion chamber pre-ignition, but post combustion, for example: o2 sensor readings, or emissions sample.
video_voide
Engine Management and Tuning
11
Feb 22, 2013 11:48 AM
DEMNTD1
Jun 28, 2005 05:19 PM
Attoir
Mar 18, 2004 01:25 PM
tc
Sep 22, 2003 06:10 AM
Veil_Side_
Jan 6, 2002 12:30 AM
