itr master cylinder/booster on eg hatch problems help!
Old Feb 13, 2013 | 06:03 PM
hytechb20's Avatar
Icon2 itr master cylinder/booster on eg hatch problems help!
the car - 1995 civic si hatchback
4 wheel disc
30/40 proportion valve (stock)
i recently swapped the brake booster and master cylinder on my hatch with a 1" b18c type r one. first thing i noticed is that the booster doesnt sit flush with the firewall. i went ahead and relocated the 30/40 proportion valve inside the cabin to tuck to the lines and got every line plugged in to the right hole on the proportion valve. when i went to bleed the system i filled the reservior and began to pump and bleed the right rear which bleed a little now the other lines wont bleed... the fluid just stays in the reservoir and wont go into the lines??? could i have the fittings on to tight? would i have one of the master cylinder lines mixed up on the proportion valve? this is getting a bit frustrating if youve done before where do you have the two master cylinder lines located on the proportion valve? diagrams??? help?
Old Feb 14, 2013 | 12:07 AM
axis11's Avatar
Default Re: itr master cylinder/booster on eg hatch problems help!
Did you bench bleed the master cylinder before you installed it? If not, you will have a hard time bleeding the system.
Old Feb 14, 2013 | 05:38 AM
JuggerNaut-CTR's Avatar
^x2
Gabriel Johnson
Suspension & Brakes
Jul 17, 2014 11:59 AM
civicexowner
Jun 18, 2009 03:07 PM
Del Sol on Steroids
Mar 5, 2008 07:52 PM
