axle removal
Old Feb 13, 2013 | 03:32 PM
WhiteTrashedDA9's Avatar
Icon2 axle removal
Hey ht I'm trying to remove the drivers side axle on a 94 accord. i removed the passenger side axle with no problems using an 8 in pry bar very lightly. I'm trying to do the same with this axle connected to the half shaft but am having no luck I've tryed 2 pry bars on oppisite sides.
I'm at a loss on what to do any help is appreciated !
Old Feb 13, 2013 | 03:38 PM
GagnarTheUnruly's Avatar
Default Re: axle removal
Use a pry bar and apply moderate pressure. Take a hammer and sharply hit the CV joint housing from behind (the transmission end). It should pop right out. If not, just keep trying until you get it. It seems impossible until you figure out how to do it, and then it's actually quite easy!
Old Feb 13, 2013 | 03:42 PM
Fliptard's Avatar
also try spinning it and hitting it in diff spot. Sometimes you just gotta find the sweet spot.
Old Feb 13, 2013 | 03:48 PM
Thanks for the quick reply guys ill try again tomorrow let u know if i have n e luck
Old Feb 13, 2013 | 07:03 PM
All I can say is keep at it. It'll feel like it'll never work and then -- pop -- you're done, super easy. Once you've done it a few times you get a feel for it.
Old Feb 15, 2013 | 03:01 PM
Thanks a lot guys!!! gagnars tip of tapping on the end of the halfshalft lighty was what made a big difference in poping that axle out!
Old Feb 15, 2013 | 08:09 PM
Old Feb 16, 2013 | 09:30 PM
gizmo775's Avatar
had the same problem today
got it tho with a little tap here and there
grjr
Aug 23, 2012 04:12 PM
Boosthead
Jul 12, 2005 12:57 PM
Boosthead
Jul 10, 2005 10:32 AM
ericlee303
Mar 1, 2004 11:57 AM
Doogie Howser
Sep 5, 2002 06:44 PM
