94 GS-R
Old Feb 13, 2013 | 12:54 PM
doingthemost's Avatar
Default 94 GS-R
First off, I'm new here and don't know much about cars but willing to learn. Now the problem I've encountered is that the car keeps scraping underneath because it's too low. I've tried angling but had no luck. Any opinions on what I should do? The car is my DD and the roads around here aren't the best.
Old Feb 13, 2013 | 12:56 PM
doood's Avatar
been there done that
Default Re: 94 GS-R
Raise it?
Old Feb 13, 2013 | 12:58 PM
Default Re: 94 GS-R
I've was thinking of doing that, any recommendations to it? I believe the current springs are cut from the feel of the drive.
Old Feb 13, 2013 | 12:59 PM
Fliptard's Avatar
Default Re: 94 GS-R
by new springs, or coil overs and raise in up.
Old Feb 13, 2013 | 01:00 PM
'Merica!'s Avatar
Default Re: 94 GS-R
get some new shocks and springs.
Old Feb 13, 2013 | 01:03 PM
Default Re: 94 GS-R
any recommendations to the shocks/springs? Is it worth buying some cheaper shocks/springs or should I save for koni yellows/gc springs? The car is just a DD and once in awhile a little pleasure driving.
Old Feb 13, 2013 | 01:17 PM
GagnarTheUnruly's Avatar
Default Re: 94 GS-R
Useful information here, along with a moderate degree of bandwagoning:
https://honda-tech.com/forums/suspension-brakes-54/click-here-all-you-curious-about-suspension-setups-their-costs-reliability-2967499/
Koni/GC is a no-brainer if it fits your budget, but other good options are available. Progress is probably the best choice for someone on a tighter budget, as long as you are OK with a 1-1.5" drop (and no more or no less). You can get lowering springs (e.g. Eibach ProKit) on OEM-replacement shocks (e.g. Tokico blues, KYB AGX, Koni red), but the price approaches Progress and you don't get height-adjustability.
I have progress cs2 350/250 and they are very good. See my build thread for impresssions:
https://honda-tech.com/forums/showthread.php?p=47242031
Old Feb 13, 2013 | 01:20 PM
Default Re: 94 GS-R
I'm gonna take a look at the koni oranges/progress. Thanks for the link! I'm not looking for too much of a drop at all, the ride becomes uncomfortable as well lol.
Old Feb 13, 2013 | 01:24 PM
Default Re: 94 GS-R
Ya you definitely lose some ride quality with higher rates. You also need pretty high rates for even mild drops. If comfort is what you are after ProKits are good, but they do drop just a little too much. I'll be selling a set soon (on OEM shocks). Pm me if you are interested.
Progress is great as well and it has the advantages of being a "full" coilover.
Old Feb 13, 2013 | 01:27 PM
Default Re: 94 GS-R
Heck, at one point I was thinking of going stock height considering I'm mainly concerned for the scraping of the underbody/lip along with ride comfort.
Old Feb 13, 2013 | 01:35 PM
Default Re: 94 GS-R
You can get close to stock height on Koni/GC as long as you chose the correct length springs. The Koni shock body is OEM sized, so it can "handle" the stock height. Progress, on the other hand is shorter, so stock height is literally impossible. In my experience a 1-1.5" drop is fine on basically all roads and speedbumps, and 95% of driveways (and this is in Montana and Reno where the world seems built for trucks). Any lower and you start scraping, and scraping is lame.
Ride quality is harder to get around. Better performance will come at the cost of ride quality. If it's a major concern, I recommend starting with an ITR sway bar. Even on a stock suspension it is HANDS DOWN the most effective performance upgrade on Integras (excluding summer tires), and it has a negligible effect on ride quality. ITR sway plus ProKit is stiffer than stock but still in the normal OEM range of ride comfort for performance-oriented cars. Progress 250 rate rear springs are getting to the limit of what people would notice and/or comment on. Beyond that and you're really talking about a stiff-riding car.
Old Feb 13, 2013 | 01:38 PM
Default Re: 94 GS-R
What would be the correct spring length on Koni/GC? I'm utterly confused.
Old Feb 13, 2013 | 02:25 PM
Default Re: 94 GS-R
Spring lengths are confusing unless you've got everything right in front of you. It has to do with having enough wiggle-room for raising and lowering your car that the spring won't come off its perch. I believe OTS springs for Koni/GC are 380/250 8" springs and those will be fine for a 0-2" drop.
Old Feb 13, 2013 | 05:27 PM
GZNDEG's Avatar
Default Re: 94 GS-R
I'm on skunk 2 2.5/2.25" springs with tokico hp. My biggest concern has always been drivability, and the combo works well on the street. Pretty smooth over road imperfections. Handles just fine through the curves.
Old Feb 14, 2013 | 09:01 AM
3rdtimecharmer's Avatar
10 Year Member
Default Re: 94 GS-R
a nice set of new suspension goes a long way. u will love it. dont take shortcuts, like the previous owner, and enjoy your diamond in the rufffffffffff. bark meow.
Old Feb 14, 2013 | 09:52 AM
Default Re: 94 GS-R
Thanks, I'm gonna start saving up for some Koni shocks and GC springs.
bigbpatel
Aug 13, 2012 08:10 PM
Niskyspy
Aug 25, 2007 08:29 PM
fanatix
23
Oct 12, 2004 08:03 PM
1.8man
Mar 29, 2003 07:32 PM
andrew n
Jan 27, 2002 09:49 PM
