96 lx sedan braking problem
Old Feb 13, 2013 | 12:31 PM
pimmy98's Avatar
Default 96 lx sedan braking problem
ok so i have taken my car to 2 mechanic shops now. nobody can tell me whats wrong. my brakes work but they fail sometimes, usually at low rpms and especially while parking. if i hammer them to the floor they still work. most of the time there firm and work well but then all of a sudden they go right to the floor. i just replaced the master cylinder. they've been bled. its non abs so what the hell can it be. ive heard proportioning valves never go? if i did how cud i tell...any help is appreciated
Old Feb 13, 2013 | 02:53 PM
Texas4door's Avatar
Default Re: 96 lx sedan braking problem
Test your brake booster check valve. It's supposed to hold vacuum so you can have brakes at lower RPM's (or if the car shuts off).
Run the car for a few moments and then shut it off. Pump the brake pedal. If the pedal firms up, the valve is good. If not, it's bad and should be replaced.
Same thing happened to me and it took me a good while to figured it out.
Good luck!
Old Feb 13, 2013 | 07:12 PM
dazebreak's Avatar
See attached...
File Type: pdf
tim_r95
Mar 10, 2015 07:50 AM
GnrlKll
Suspension & Brakes
10
Dec 30, 2012 07:36 AM
tlmg21700
Aug 13, 2008 06:25 PM
jaideep_asokan
Oct 2, 2007 09:42 AM
onyx00
Jun 3, 2004 05:57 PM
