does someone know how to stop a water leak??
the red mark is where the water comes in
http://s2.subirimagenes.com/fotos/pr...0212181953.jpg
http://s2.subirimagenes.com/fotos/pr...0212181941.jpg
try taking the inner panels off the roof unbolt the roof latch locks and put a washer or 2 under each bolt on all 4 corners and it will pull your roof down tighter I did 1 and it stopped my water leak
that or try some silicon spray your seals real good
Idk after looking at that second pic you might need a new seal
its a 93 seal. they have been known to leak in almost 99% of del sols
score some 94-up seals and replace them
use silicone spray to keep the rubber from deteriorating .
once you can hear squeaking from your seals apply silicone spray
Kyles ej1
12
May 10, 2005 03:40 PM
PatrickGSR94
Jan 13, 2005 12:21 AM
