Ef wiring problem??
I have a 88 civic sedan with a d16z6 swap. I was using boomslang wiring harness but ran into some problems with that harness with the car not starting. So i decided to upgrade to the chasebays harness which i have installed. Only thing is now that i have it installed it doesn't want to hold an idle and has a check engine code of 20 which is the electronic load detector. Its running on a p28 a02. I've checked all the grounds and everything is good. Lost on what else to do. Any help would be much appreciated.
Thanks,
matt
Thanks,
matt
sepetinswenze
Nov 25, 2010 05:25 AM
RedEFonSIrims
12
Feb 10, 2009 02:29 PM
