Del Sol Cabin harness
Old Feb 12, 2013 | 10:05 AM
Carlos Peralta's Avatar
Default Del Sol Cabin harness
I got a question for all the techies out there. I've got a 93 5spd. del sol and the cabin harness was cut up pretty badly. I wanted to know if an automatic harness will work or not because I'm not having any luck finding a stock one.
Old Feb 12, 2013 | 07:02 PM
fcm's Avatar
fcm
Old Fart
Default Re: Del Sol Cabin harness
Assuming you mean the dash harness, the harness for the automatic is different then the 5 speed, no CIS wiring , no starter relay wiring, [starter wiring would have to change] back-up lights wiring would need to change and although you can make it work, it would be a fair amount of work so you don't just end up with a "cut up pretty badly" auto harness to replace your cut up manual harness, probably less work to pull your dash harness and repair it. 94
gohanmoka
May 24, 2010 05:40 AM
Nate.Hamm
Aug 3, 2007 08:32 PM
slksol
Aug 25, 2003 08:41 PM
DragII
Nov 26, 2001 10:38 AM
