Turbo GSR civic stalls on idle
Old Feb 11, 2013 | 04:59 PM
rice a roni's Avatar
Default Turbo GSR civic stalls on idle
Had this problem ever since I installed the phearable 70mm throttle body. At first it was just idle'ing low, but now every time I go to start the vehicle, hot or cold, it will stall unless I keep my foot on the throttle. Once I get going though it won't stall until I shut it off and try re-starting the vehicle. Thoughts?
Old Feb 11, 2013 | 05:11 PM
Former User's Avatar
Default Re: Turbo GSR civic stalls on idle
Have you cleaned the IACV and adjusted the idle speed?
CEL codes?
Old Feb 11, 2013 | 06:14 PM
grumblemarc's Avatar
The Grumpiest
Reinstall old TPS onto new TB? Then recalibrate the TPS. If none of the above? Retune for the TB. You just introduced more airflow into the system and should do so anyway.
that_boy_sammy
15
Nov 23, 2009 12:15 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
924doorEG
Nov 19, 2007 08:15 AM
foumer
May 7, 2006 07:37 AM
