Shifter bushings
Hey guys. I got a 95 civic ex. My shifter is really loose and I kno it's the bushings. I have no clue on how to replace them. Although I do have the ones I need. Could someone explain. Possibly a diagram or photos?
I'm assuming its the same as 07. Anyways, unbolt the shift stabilizer bar thing from the transmission. Pry, hammer, whatever the old one out. Put in new one. Bolt back together. Go back to where the shifter comes through the floor and unbolt the bracket. Slide the bushing off the wiener thing. You might have to squeeze the tip a little to get started. Slide new one on. It helps to lube the hole before sliding it in. Bolt the bracket back on.
Enjoy your stiffer stick.
swizz977
Nov 22, 2011 07:34 PM
