Venturi vacumm in intake manifold accord 91
Hi all, I have a 91 accord, I'm seeking help from you because I need to find inlet venturi vacuum in the intake manifold, venturi vacuum is when the couple will throttle the more speeds generates more suction, thank you all
please proof read again and try explaining in more detail- clarify.
are you trying to find a place on the manifold to fit a vacuum line to? you can really "T" off of anything for that.
If you're trying to install a venturi vacuum device i would be very interested to know what your purpose/plan is. this may help someone suggest a different device or method to accomplish your goal.
Hi, I was looking for a vacuum venturi, found one in the steam coming from the gas canister, I want it for my project of HCS, is very weak, thanks
Hydrocarbon Cracking System you can see here
http://www.fuel-saver.org/Thread-Hyd...racking-System
thanks
thanks
NB4 laws of thermodynamics are posted.
Are you looking for ported vacuum sources?
I thought there were two or three ports on the throttle body. Pick and choose which port has the correct amount of vacuum.
You are going to have to find a separate vacuum port. One that doesn't already have something running to it.
If you are willing to go through all of this to get this cracker setup. I'm sure you can find a way to drill and tap a new vacuum port into your intake manifold.
Wish you the best of luck with this snake oil project. Hopefully you don't burn your car, blow yourself up or anyone else while running this system.
eptcrx91
Apr 26, 2013 10:32 AM
integranator
Jun 18, 2007 05:51 PM
