Si cluster Help to
Old Feb 10, 2013 | 08:17 PM
19da90's Avatar
Icon3 Si cluster Help to
Si cluster in 93 civic have them in i see a red and black wire and then a box that runns to a switch that say's green are blue i dont mind the collor its stuck on how i get it to light again? Help to make them power with in dash switch. Old one with switch before some on ripped it out need it to run off battery. ARE ?
Old Feb 10, 2013 | 08:40 PM
Former User's Avatar
Default Re: Si cluster Help to
I don't understand what the problem and question are.
Old Feb 11, 2013 | 06:52 PM
19da90's Avatar
i need to light my clusters up they are in place the old switch wire's were ripped outfrom the switch.
how to jimmy rige to battery......
Old Feb 11, 2013 | 06:55 PM
Splice the dimmer switch connector red wire and black wire together and the cluster lights should work at full intensity whenever the parking lights are on.
Old Feb 11, 2013 | 06:56 PM
grumblemarc's Avatar
The Grumpiest
Sounds like you're talking about some indiglo gauge face overlays. There's a rheostat that controls that somewhere. If you're saying that's it's not working then I'd remove the overlays and get some new ones. They're too cheap to try and risk fouling up wiring trying to rig up something.
Are you typing this on your phone? If so, stop it or write complete coherent sentences.
Old Feb 11, 2013 | 08:26 PM
19da90's Avatar
ok thanks and yes its a little black box that kinects to the switch that can turns them from blue to green.. and it has a dimmer *** on it.. were can i get on of these and how easy it it to install.. The other end is still in the dash with the cluster.. i see the black and red wire then the all black wire is cut. then there is a wire that black that goes to the switch that had a chip under it to stotter to the switch board. "THAT BROKE TO"
Old Feb 11, 2013 | 08:36 PM
19da90's Avatar
and it is a SI cluster
Old Feb 11, 2013 | 09:00 PM
19da90's Avatar
si clucter dash.... https://sphotos-b.xx.fbcdn.net/hphot...67449371_n.jpg
wire's black and red.. and the chip to the switch thats broken on corner..https://sphotos-b.xx.fbcdn.net/hphot...60258383_n.jpg
and this is the black box thats the brian i guess... :D https://sphotos-a.xx.fbcdn.net/hphot...47510843_n.jpg
Old Feb 12, 2013 | 02:23 AM
The Grumpiest
Try Ebay.
Old Feb 12, 2013 | 05:21 PM
19da90's Avatar
nothing
Old Feb 12, 2013 | 05:29 PM
The Grumpiest
Rubbish. You're not looking hard enough. If anything get a new set of overlays.
Kevin_Ceee
Oct 25, 2012 08:48 AM
MilanoEj1
Sep 27, 2010 09:52 PM
93grayeg
Aug 24, 2010 10:53 PM
white_ej6
Aug 27, 2009 10:33 PM
D@nnY
Mar 4, 2004 07:07 PM
