98 Civic EX Cylinder 2 Missfire
Recently replaced the headgasket on my d16y8, heat finally works again and no longer overheats. Not 3 days after the replacement it started struggling (Check Engine Light flashing, Rough running, hesitation, jerking when accelerating), hooked my laptop to obd2 and it gave me "P0302 Cylinder 2 missfire".
The weird thing is theres not really a pattern to it. some days it does it struggles, others it doesnt. It also never has a problem once it gets over 3k rpm. Almost always struggles when going uphill though.
Timing is dead on, and it just passed inspected at the honda dealership after i put in the headgasket. Any ideas what to do?
whens the last time the plugs, wire, dizzy cap and rotor button were changed?
my car did that a while back.. almost acted like there was a dead spot in it for a while... pilled the cap off and it was burnt to a crisp.
havent checked the fuel system, i dont have too much experience with cars so im not sure what that would entail. The headgasket was my first real diy car work, i just used a chilton manual. and the previous owner said he got a tune up before he sold it to me, which would be about 40k miles ago. Although he may have just said that to make it more appealing.
http://shop.advanceautoparts.com/web...vron_7080109-p
check engine light flashing means catalyst damage is occurring, 99.9% of the time its an ignition problem. there's entirely too much fuel getting to the cat try an ignition tune up will most likely solve your problem. especially under load, under load if you could have a "leaky" plug wire or cracked porcelain on the plugs, spark is jumping to ground causing no burn in that cyl
http://img694.imageshack.us/img694/2...0212212123.jpg
http://img600.imageshack.us/img600/6...0212212111.jpg
Heres the electrode end, ill post a video of the plug pushing itself up when it finishes uploading.
http://img401.imageshack.us/img401/2...0213121315.jpg
http://img809.imageshack.us/img809/8...0213121230.jpg
I think i found the problem, all the plug wires except cylinder 2 almost "click" in when they catch on the spark plug. #2 plug wire is free moving, the wire just slides in and out with no resistance and isnt catching on anything. I did a temporary fix by taking a pair of needlenose pliers and clamping the metal in the plug wire a little tighter. Its running smoothly now, but im going to replace the the plugs/wires. after 145k miles i think its about time...haha
thanks for all the ideas from everyone
TNight
Jun 18, 2017 05:03 PM
TNight
Jun 18, 2017 08:39 AM
thatsarad1
Sep 14, 2009 06:09 PM
