Rev limitting at 3500 and buzzing fuel relay
Old Feb 10, 2013 | 03:24 PM
CMunsterman's Avatar
Default Rev limitting at 3500 and buzzing fuel relay
I have a jdm b16a and recently its started rev limiting at 3500 and the speedometer jumps around when it does it. whenever the speedometer jumps around my fuel main relay buzzes, so i replaced that and it stopped for like a day and now its doing it again. i'm also getting CEL codes 16 and 41, but ive had 41 before its done it so i think its something with the fuel injectors but i'm not really sure what to check.
Old Feb 10, 2013 | 04:47 PM
Former User's Avatar
Default Re: Rev limitting at 3500 and buzzing fuel relay
Have you cleaned and tightened the G101 ground attached too the thermostat housing?
Old Feb 10, 2013 | 08:11 PM
i haven't checked any grounds, but i'll check that out tomorrow. thanks
Old Feb 11, 2013 | 12:10 AM
G_thirty_5's Avatar
Check your connection wires to your ivac and change your speed sensor. Possibly your ivac needs to change a
Aswell
Old Feb 11, 2013 | 12:33 AM
TomCurllyFry's Avatar
i have the exact same problem lol same cel as well let me no if you find out
Old Feb 11, 2013 | 05:26 AM
Originally Posted by G_thirty_5
Check your connection wires to your ivac and change your speed sensor. Possibly vivacity aswell
Where is the speed sensor located?
Old Feb 11, 2013 | 05:33 AM
I would disregard the top post. It makes little sense and is also odd. I'm watching this member.
Old Feb 11, 2013 | 09:50 AM
G_thirty_5's Avatar
Its on your trans in the back
Old Feb 11, 2013 | 02:57 PM
Just fixed it. Ended up being the ground for the vtec pressure solenoid (oil pressure sensor) it was half connected and snapped off when I touched it
Old Feb 11, 2013 | 03:42 PM
The oil pressure switch grounds at G101 on the thermostat housing.
Old Feb 12, 2013 | 06:54 AM
Weird..my g101 ground was totally fine but I barely touched the ground directly underneath the intake and it snapped right off. Fixed it, started first time
Shane Henry
Mar 5, 2014 05:14 AM
95PreludeNAed
Jan 10, 2012 04:09 PM
b17itr
Feb 7, 2011 07:45 PM
slonlow
Apr 14, 2009 03:42 PM
TheTealHatch
23
Oct 14, 2008 12:01 PM
