Honda CR-V & Element 2WD & 4WD Element & CR-V
gen 1 crv fortune auto coilovers
Old Feb 10, 2013 | 01:45 AM
Bstrass11's Avatar
Default gen 1 crv fortune auto coilovers
Does anyone know if the top mounts on the gen 1 fortune auto coilovers have adjustable camber? If not what are some options that are moderatly priced?
Old Feb 10, 2013 | 12:56 PM
NZ-DB8R's Avatar
Default Re: gen 1 crv fortune auto coilovers
No, altering the angle of the strut does not change the camber. Same as Civic and Integra etc of same era.
You need adjustable camber arms or balljoints to change the camber
Old Feb 10, 2013 | 03:34 PM
Bstrass11's Avatar
Ah thank you sir. Is there anywhere to find these for under a 100 bucks each? The few that I can find are crazy expensive.
Old Feb 10, 2013 | 05:53 PM
LDForget's Avatar
I run SPC extreme adjustable prelude ball joints. i paid 125 (i think, its in my build thread) for the pair (or it might have been each?)
Old Feb 10, 2013 | 09:12 PM
Bstrass11's Avatar
I found the SPC extreme for the first gen crv's, Im just wondering if the +3 adjustment is enough for a 2-3 inch drop. Never really messed with suspension before so I am hesitant before dropping money like this haha.
Old Feb 10, 2013 | 09:40 PM
dpapichulo718's Avatar
in my opnion if u droping it im using d2 coilovers and d2 rear camber kit from the ek and i got -5.5 camber in my crv 1st gen and also before lowering it giving u a head up shave down you upper control arm or they would get stuck
Old Feb 10, 2013 | 10:20 PM
LDForget's Avatar
I'm lowered 7"
Old Feb 10, 2013 | 10:48 PM
Bstrass11's Avatar
Really shave down the control arms!? Even if I am only gonna drop it a few inches, Im not gonna lower it more than prob 4 in the front
Old Feb 10, 2013 | 11:53 PM
yea shave them just a lil dont ode u dont want the ball joint popping out lol but yea eev if u lower it a lil it would get stuck to the frame so make sure u shave it or it would get stuck i seen it happend to many ppl even myself
Old Feb 11, 2013 | 12:33 AM
Bstrass11's Avatar
Well now I have seen boosteds thread and he has nothing to adjust front camber and seems to be fine. The extra 200 saved would def help my decision. Is it ok to lower without anything for stock camber adjustment?
Old Feb 11, 2013 | 04:53 AM
LDForget's Avatar
you can lower it a bit, but it will promote inner tire wear. Im lowered so much i had to cut out part of my frame rail and grind down my control arms.
Old Feb 17, 2013 | 11:18 AM
jdm_bones's Avatar
Post picture of the area that was shaved, I am interested, as I will be dropping mine in the near future.
Old Feb 17, 2013 | 12:44 PM
blackskunk2si's Avatar
You don't need to shave the control arms unless you do some additional parts swapping like different struts or extended tophats. The stock crv struts will bottom out before the control arms cycle up into the strut tower to get stuck. I drove mine for years without issue. Only when I swapped to civic struts did mine get stuck. The civic struts let me have more suspension travel before bottoming out and that was my issue
Old Feb 17, 2013 | 01:00 PM
LDForget's Avatar
Mine got stuck up there a couple times before i swapped to civic struts, but i was able to get it unstuck. once i swapped to civic struts it got stuck up there and there was no room. had to cut everything out and grind it down.
Old Feb 17, 2013 | 01:03 PM
I rode for 3 years dumped on coilovers and stock crv struts without getting stuck.
Old Feb 17, 2013 | 01:37 PM
LDForget's Avatar
Each situation is different I suppose. Mine was fine for months then ended up getting stuck twice.
Old Feb 17, 2013 | 03:33 PM
That's a scary *** thing when it happens too ain't it hahaha
Old Feb 17, 2013 | 03:42 PM
LDForget's Avatar
**** yeah. i was going over some tracks the first time and the bump completely compressed my suspension. on the side of the road i go. lol. The difference between my experience and yours could have been that i nearly completely removed my bump stops. did you cut yours?
Old Feb 17, 2013 | 04:03 PM
I removed 3 out of the 4 bumps off of the bumpstop
Old May 22, 2013 | 12:02 AM
neu-b's Avatar
My first drive after my drop I jammed both control arms in so hard I locked up my fronts from the tires jamming so hard into what was remaining of my rails (I had also ground about 1/2" off the end of both UCA's). The roads out here are pretty shitty though and speed has a huuuuuge impact on the likleyhood of getting your upper control arms stuck. Needless to say I stuck to back roads for a bit till I got that sorted out.
Old May 24, 2013 | 05:57 AM
Skillachie's Avatar
Train tracks?
GoLowDrew
Suspension & Brakes
Jun 6, 2015 04:46 PM
FreshxJDM
Jun 20, 2012 12:05 PM
honda607
Jun 7, 2003 07:17 AM
DanHill
Feb 28, 2002 10:09 AM
vpforeva
Jun 7, 2001 09:04 AM
