97 civic hx/d16y7 swap - Intake failed CA visual inspection. Is egr needed?
Old Feb 10, 2013 | 12:07 AM
tecatown2091's Avatar
Default 97 civic hx/d16y7 swap - Intake failed CA visual inspection. Is egr needed?
alright so I got a hx and swapped to d16y7 it still had the y5 intake and it has a egr.i went to the cali state ref to get it inspected and I failed visual because I have wrong intake .I brought a y7 and its on its way but the y7 uses no egr.it passed emissions part with out egr .just failed on intake visual .does California need to read egr to pass smog?he said that the y7 ecu doesn't read egrs .do I need one when I go to pass smog.its impossible to put a egr on a y7
Old Feb 10, 2013 | 02:08 PM
Default Re: 97 civic hx/d16y7 swap - Intake failed CA visual inspection. Is egr needed?
no one knows???????
Old Feb 10, 2013 | 02:12 PM
94EG8's Avatar
Seagull Management
The intake manifold needs to match the engine, so does the exhaust, and the ECU and any other emissions components.
To answer your question, no it doesn't need the EGR valve. It wont mount to a D16Y7 IM anyway, and the ECU doesn't have the circuitry for it.
jmorrissey21
Apr 27, 2013 12:14 PM
skrewdriver88
Aug 24, 2004 07:26 AM
acme
31
Oct 16, 2003 08:38 AM
Spade
Dec 13, 2001 08:11 AM
