HELP!!! Strange noise in my steering
Sup HT,
I recently just replace my right outer tie rod, right front spindle, & left front axle on my 97 SE. As of thursday, ive notice a grinding noise coming from the driver's side tire. If anyone has had this issue after replacing their axle, please feel free to offer suggestions! Thanks!
Is the axle nut tight and staked? Are brake calipers tight? Did you bend brake shield and it is rubbing against rotor? Is the wheel bearing good?
UPDATE: turns out the grinding noise was from a worn out hub on the drivers side! Thanks fellas!!!
