h22/civic eg - bogs out at more than half throttle
Old Feb 9, 2013 | 05:53 PM
jdm 1080p's Avatar
Default h22/civic eg - bogs out at more than half throttle
ok so i bought a civic with h22 swap and it was fine. untill i lost all power i dont know what it could be?
Old Feb 9, 2013 | 10:38 PM
jbpnoman's Avatar
Default Re: h22 civic eg help!!!
You need to give us something to work on here. Have you bothered testing ANYTHING yet? What exactly do you not have power to?
Old Feb 10, 2013 | 05:48 AM
jdm 1080p's Avatar
It boggs out when i go more then half throttle. Runs still every time. Just lack of engine power. It is a jdm h22a red top. With chiped p28. So far i tested to see if there was any conectors that came loose. Now i am trying to find a different dizzy and wire harness because there both hacked up. Could it bog out from low gas? Its almost on e. Like i said before it dosent have any engine power like starts but boggs when u give it more then half throttle
Old Feb 10, 2013 | 06:03 AM
spencer47's Avatar
check all your fuel lines such as fuel pump, injectors, and even your fuel filter. if it's clogged or old it could not give you the proper amount of fuel you need when under that amount of throttle.
Old Feb 10, 2013 | 09:24 AM
jbpnoman's Avatar
Default Re: h22/civic eg - bogs out at more than half throttle
Never let your fuel gauge go below a quarter tank. That's a basic part of good car maintenance. Is the CEL on? Does it work? Is your P28 tuned to run the motor? Have you checked your ignition and mechanical timing? When was the last full tune-up?
Old Feb 10, 2013 | 10:05 AM
hwyix's Avatar
And your fuel pump will last longer because it is always submerged in gas. (gas cools the pump).
If you fill your tank up and the problem goes away it could be this problem.
https://honda-tech.com/forums/tech-misc-15/90-civic-dx-hatch-dies-half-tank-someone-please-help-me-3121051/
Old Feb 10, 2013 | 11:25 AM
Former User's Avatar
^this
Old Feb 10, 2013 | 04:53 PM
jdm 1080p's Avatar
this car ran perfect before then all of a sudden no power what so ever!!! just like that some one was telling me the distributor is fucked up since it doesn't line up wit the holes... but its p13 distributor so idk? so I should put my gas up to half or more and see if the problem has changed? should I buy a walbro 255 pump or civic one would work?
Old Feb 11, 2013 | 01:08 AM
jbpnoman's Avatar
I asked you five questions. Ron agreed with one of them. You didn't answer any of them. We can't help you if you don't help us.
Old Feb 11, 2013 | 04:42 AM
jdm 1080p's Avatar
for some reason cel doesn't work with this ecu? yea the motor was tuned with this ecu I even have dyno sheets. i put spark plugs in it yesterday, other then that i have no clue when this had a full tune up. my friend said its in limp mode and also something about the cam sensor in the dizzy? im just gonna buy a new one and do a full tune up as well see if anything changed. also the timing is spot on
Old Feb 11, 2013 | 06:08 AM
jdm 1080p's Avatar
ok here is check engine light I think its just 10? witch is iat sensor...
http://www.youtube.com/watch?v=XrNbA...ature=youtu.be ima change the dizzy fuel pump fuel filter and do a compression test... but now the car smells like gas so maybe its not getting enough fuel.. is stock civic fuel pump to weak for it?
bb4arson
Apr 20, 2008 12:28 PM
TeamRiskEG6
Jan 25, 2007 12:33 PM
htchbak
Oct 9, 2003 03:02 PM
jdmh22bubble
May 11, 2003 12:40 PM
LD_EGSICK
May 15, 2002 07:04 PM
