I need HELP with my, H22 eg
I have had my h22 swap for about 1 year,now I have a problem. When i go down the road and keep the gas steady the car trys to sputer,and starts to slow down,but if i give it the gas it stops and will start speeding up.I have gave the car a full tune-up and it still does it.Some days it does it and some not. HELP!
Re: I need HELP with my, H22 eg (jdmh22bubble)
Sounds like you might need a fuel management system. I've seen h22 swaps that when you drive them, it's either all the way on the throttle (well atleast %50) or off the throttle. tough to diagnose not being there though. Good Luck
Re: I need HELP with my, H22 eg (delslo26)
I have a v-afc controller but i do have the stock fuel pumo from my civic .What fuel pump whould you guys recomend.
I have a v-afc controller but i do have the stock fuel pump from my civic .What fuel pump whould you guys recomend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22bubble »</TD></TR><TR><TD CLASS="quote">I have a v-afc controller but i do have the stock fuel pumo from my civic .What fuel pump whould you guys recomend.</TD></TR></TABLE>
There's your problem. A good pump is a Walbro 190lph or a 255lph pump. With the 255lph pump you might run rich so it is recommended(by the h22a guys) to get a fuel pressure regulator and fuel pressure gauge.
