Hard starting
Old Feb 9, 2013 | 03:53 PM
kjrayo18's Avatar
Default Hard starting
Hey guys i have a 95 accord Automatic which sometimes wont start and barely cranks at all. But other times it just starts. Ive changed the starter, battery, dist cap and rotor and nothing. Heres a vid I just took http://www.youtube.com/watch?v=tOChN...ature=youtu.be it usually dies after the grinding noise.
Old Feb 9, 2013 | 05:30 PM
jdowen2's Avatar
Default Re: Hard starting
Have you tested charging of battery while running? You should be reading about 13vdc or more. If that looks good your starter solenoid could be flakey. Also, make sure all battery connections are clean and tight and the cable on the starter has a clean and tight connection.
Old Feb 9, 2013 | 05:51 PM
kjrayo18's Avatar
I'm going to check the voltage tomorrow. just curious tho, if it always turns on doesn't that mean is charging?
Old Feb 9, 2013 | 06:06 PM
jdowen2's Avatar
Possible alternator is not putting out full charge. Is the alternator belt the right tension? You have to eliminate possibilities.
Cutty408
Oct 29, 2018 07:56 AM
Cap'N Chronic
44
Sep 3, 2011 10:44 PM
dvlsfan30
Feb 11, 2009 09:45 AM
SiB16A
Jun 11, 2006 12:37 PM
rafiq7
Dec 14, 2004 07:46 AM
