Windshield washer question
Old Feb 9, 2013 | 02:28 PM
94 IntegraLS's Avatar
Default Windshield washer question
I have a 96 Integra and whenever I hit the windshield washer it activates the fluid but the wipers wont wipe unless I turn them on. Is there a relay that controls this? or is the wiper switch junk?
*Edit*
I just looked st the service manual and it says to check the washer motor and the wiper motor. The fluid pumps out so im assuming the washer motor works fine. Is the wiper motor junk then?
Old Feb 9, 2013 | 07:27 PM
Crazed_GSR's Avatar
Default Re: Windshield washer question
I wouldn't say the wiper motor is junk if it works when you turn it on. Are we talking about the back windshield or front? I know for the back, it requires you to flip it on to work. If its the front, I'm guessing its the relay's issue.
Old Feb 10, 2013 | 07:49 AM
Front wiper since I have a sedan. I can't find a relay for the windshield wiper/washer so I was wondering if anyone has had this issue before.
Old Feb 10, 2013 | 09:07 AM
fcm's Avatar
fcm
Old Fart
Check ICU, although the wash/spray function is a direct feed from the wiper switch, [12V+] the wipe function is controlled by the ICU, along with intermittent wipers and wiper "park".
Problems with the ICU, [integrated control unit] is common on older Honda/Acura.
Most/common symptoms of a bad ICU are, no intermittent wipers, no rear window defog, no dome light off drivers door, loss of warning chimes, [seat belt, lights still on, key still in ign.]. 94
Old Feb 10, 2013 | 11:06 AM
Where is the icu located?
Old Feb 11, 2013 | 07:56 AM
fcm's Avatar
fcm
Old Fart
On the back of the under dash fuse box...
http://www.ebay.ca/itm/96-97-Acura-I...9ba27d&vxp=mtr it's the white box, it has a harness plugged into it and the ICU is plugged into the fuse box. 94
cd5stella
Apr 21, 2014 05:57 PM
voodooutt
Dec 24, 2007 09:08 PM
jxhxb
Dec 22, 2007 06:02 PM
go2sleep
Sep 2, 2007 10:08 AM
Hondasaurs
Jul 19, 2003 07:52 PM
