Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Vtec engine in my lx causing issues or ok?
Old Feb 8, 2013 | 09:09 PM
92eg6lsvtec's Avatar
Default Vtec engine in my lx causing issues or ok?
I just bought a 2001 civic lx that the guy had swapped a vtec engine into using the lx harness and ecu. Seems to run fine but I want to know if is ok without the other components being used(vtec) etc?? Twice at around 5k rpms I've had a cel pop on for tdc sensor which threw it into limp mode. Cleared code both times and runs fine otherwise. Except the second time the battery light popped on and has stayed on.. Is the sensor cel coming from being the vtec engine? Or otherwise I believe it's from a semi clogged cat(per emissions test)
Old Feb 9, 2013 | 03:02 AM
lazlong's Avatar
Default Re: Vtec engine in my lx causing issues or ok?
The engine swap should be fine.
A bad TDC sensor/circuit would throw it into limp mode. Diagnose the TDC sensor/circuit first.
Old Feb 9, 2013 | 07:30 AM
Thanks laz, what's the best way to go about that? In 1000 miles of owning its happened twice. Like I said, both times under full throttle passing somebody at 5k rpms both times.
Terabass
Jan 21, 2020 06:07 PM
jim454
Jun 21, 2016 02:16 AM
morglum
Honda CR-V & Element
Mar 25, 2015 01:57 PM
markthomas
May 29, 2014 07:33 AM
sctan15
Aug 23, 2003 01:51 PM
