converting a 91 hatch from auto to manual
Old Feb 8, 2013 | 07:35 PM
E-mac's Avatar
Default converting a 91 hatch from auto to manual
my buddy bought a 91 hatch, he wants to convert it to from an auto to hydro manual. how hard would it be to do this conversion, would you recommend him flipping thiss car and buying another one with a stick?
any help will be much appreciated thanks
Old Feb 8, 2013 | 10:23 PM
bee_afraid's Avatar
Default Re: converting a 91 hatch from auto to manual
It all really depends on how clean the car is and how attached to it he is. I'm planning on doing an auto to manual conversion on my car but it's a granny fresh 91' with under 100k miles on it.
Old Feb 9, 2013 | 04:13 PM
E-mac's Avatar
how hard is it to hang new pedals, ya plus this things got the drivers side sub frame all rotted away, I was just seeing if anyone done and if its even worth it to
Old Feb 9, 2013 | 07:43 PM
dacrxguy's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
There is a how to guide in there.
The auto to manual swap is not difficult its is pretty much straight forward as replacing a clutch with a little but of wiring. The pedals is tricky but as long as you drop the column you should be ok.
Old Feb 10, 2013 | 07:38 AM
mike205's Avatar
It's real easy. It only took me and my buddy 4 hours to do it all
Old Feb 10, 2013 | 04:16 PM
brizzle86's Avatar
Its a straight forward swap, i dont know what tranny your looking at to do a hydro swap or why you would want to go out of your way to convert to a hydro setup unless the tranny calls for it, but if you end up putting a cable trans in it follow the instructions oh how to adjust your clutch, any idiot can bolt a trans in, but im usually fixing a customers car because they set the clutch cable too tight and burned it up. just a word of caution, best of luck
Old Feb 11, 2013 | 02:08 AM
skill178's Avatar
pretty much bolt-in, better off running a cable clutch assembly and buying the conversion kit online to connect a hydro to the cable, if you try to run a hydro clutch it will be ALOT harder.
conversion kit just bolts on the front of the tranny and your cable connects to it instead of running lines and a MC from the pedal
Clumsy818
Jan 29, 2013 07:28 PM
AlfieRoach
Aug 25, 2010 06:56 PM
Xplicitz
Jul 18, 2009 04:25 AM
s0liDyNe
Sep 18, 2002 01:31 PM
