CLUTCH ISSUES! HELP!!
Old Feb 8, 2013 | 05:37 PM
Masho2013's Avatar
Post CLUTCH ISSUES! HELP!!
i have a 98 civic dx hatch and my clutch has been acting up recently. theres been way too much free play in the pedal for some reason. so i tried adjusting the rod that connects to master cylinder but it didnt help. i also checked for leaks and found nothing and i replaced the slave cylinder a couple of months ago. so is it the master cylinder?
any help would be appreciated thanks..
Old Feb 8, 2013 | 08:54 PM
TiNuts's Avatar
Default Re: CLUTCH ISSUES! HELP!!
Did you properly bleed the line when you replaced the slave cylinder?
Old Feb 9, 2013 | 06:08 AM
Masho2013's Avatar
yes the clutch felt fine after the replacement. just to make sure im going to bleed it again
Old Feb 9, 2013 | 06:52 AM
Former User's Avatar
You messed with the clutch pedal height adjustment. After you fix your current problem, you need to re-adjust the pedal height as per the service manual to avoid burning up your clutch.
Old Feb 9, 2013 | 07:30 PM
Masho2013's Avatar
seems like the master cylinder was the problem my clutch is fine once again.. i dont have a manual so how much free play is the clutch pedal suppose to have?
Osbjoey
Apr 14, 2013 08:48 AM
ohsnapzafingcu
May 16, 2011 04:30 PM
integra3586
Oct 30, 2005 09:20 PM
lude97dude
May 19, 2003 02:32 PM
h_hydrogen
Jan 30, 2003 07:07 PM
