ABS pump motor over run
Old Feb 8, 2013 | 04:53 PM
MechEng's Avatar
Icon2 ABS pump motor over run
I checked the ABS code and got:
1 pulse ...5 seconds....1 pulse....5 seconds..... 1 pulse
Then no more pulses at all. I assume this is code 1?
Not sure why it only repeats 3x?
This code represents Pump motor over run. Does anybody know the fix for this?
Thanks
PS it is for a 92 Accord ex-r
Old Feb 9, 2013 | 08:47 AM
MechEng's Avatar
Default Re: ABS pump motor over run
Tumbleweed tumbles away in the wind....
Old Feb 9, 2013 | 10:10 AM
jdowen2's Avatar
– Pump Motor Over-Run
Probable Cause[s]
1.Open or short circuit condition
2.Poor electrical connection
3.Air in hydraulic system
4.Leak in hydraulic system
5.Faulty ABS Control unit
Old Feb 11, 2013 | 03:19 PM
eagle458's Avatar
I got the same thing. Tried to bleed the ABS, but nothing came out. The ABS motor runs when jumpered or started, but nothing comes out the bleeder valve. Any ideas? Mine's a 1996 Accord V6 w/ 274,000 miles.
Old Feb 11, 2013 | 04:42 PM
poorman212's Avatar
ok...is the fluid in the abs res at the proper level?
Old Feb 12, 2013 | 12:41 PM
eagle458's Avatar
Yes the fluid is good. There is a thread here about how to remove the ABS and rebuild it. I guess I'll try that this weekend.
Old Feb 12, 2013 | 06:46 PM
Bird333's Avatar
Can you provide a link?
Old Feb 16, 2013 | 02:13 PM
eagle458's Avatar
https://honda-tech.com/forums/honda-prelude-4/abs-code-1-fix-pics-2830570/
trevee
Jul 28, 2011 09:00 PM
ullman
11
Jul 21, 2011 04:11 AM
billdrah
Sep 26, 2009 11:47 AM
Marcg611
Sep 19, 2009 01:14 PM
rhd
Nov 10, 2005 06:25 PM
