Oil leak, Civic HX d16y5, oil reappearing on intake
Old Feb 8, 2013 | 01:00 PM
ShakeZoola's Avatar
Default Oil leak, Civic HX d16y5, oil reappearing on intake
Hey everyone! fairly new user here, novice at repairs.
My civic is leaking oil, which has caused the p1491 code before, keep refilling at a rate of about 1qt every month or so, give or take a week. Code is gone for a while now, due I assume to my attention to the oil level. Oil leaks onto my intake, and i think burns as well. Twice I changed it after a mere 1k mi, but the stuff still shows very black. Help?
Never taken apart my engine block before, but i have helped once with an early 90s ford, so i have some idea about the amount of work involved.
Thanks, and please forgive my ignorance!
Old Feb 8, 2013 | 01:11 PM
Former User's Avatar
Default Re: Oil leak, Civic HX d16y5, oil reappearing on intake
Post multiple clear pictures of where oil accumulates on the engine and the believed source of the leak.
Old Feb 8, 2013 | 01:37 PM
94EG8's Avatar
Seagull Management
If the oil is turning black right away it's a pretty good indication of stuck or worn oil rings causing blowby. That or the PCV valve went bad and it's sucking oil in the intake and burning it.
Check the PCV valve, see if it rattles, if it doesn't replace it and see if that helps. If not you're probably looking at an engine rebuild or replacement.
Old Feb 9, 2013 | 11:57 AM
ShakeZoola's Avatar
Alrighty, pics will be forthcoming in the next 24 hours, and i will check the pcv. :-) will keep y'all updated, and thank you again for the replies!
jmccalip
Dec 22, 2012 09:02 AM
masijdm
11
Jan 9, 2009 09:21 PM
GO-FIGHT-KILL
Mar 25, 2008 09:23 PM
CroSi
Aug 14, 2003 04:32 PM
lsteggy
Oct 18, 2002 12:09 PM
