00 civic coupe/b16 Turbo - hard to start
Sup guys i got a 2000 Honda civic coupe with a b16 Turbo. The problem is
Sometimes lately its hard to start.. like it starts then dies out right after for about 10 times
and once i get it running it dies out outta no where... Idk?? I changed the ignition switch still the same any suggestions? Lmk any help is much appreciated thanx guys.
Its not the fuel pump.. i can hear it when i turn the key. I have 550 injector and a chip ecu.. i just bought the car not to long ago.. Idk if it could be cause it needs a tune? It also has a 3 bar map sensor..
Well, with the given info it can be a million things. For starters, hows the condition of your cap/rotor, plugs, wires? Id also check for vacuum leaks. Those kill the performance of any car with a turbo.
Thanks guys for everything!.. i just found the problem, it was the ignition coil fuse. The fuse wasn't in the socket good so it didn't have good connection. Thanx for the help though much appreciate it.
umair
Aug 2, 2011 11:06 AM
