99 civic si head gasket problem
Old Feb 7, 2013 | 05:00 PM
MHM2008's Avatar
Default 99 civic si head gasket problem
So i had a blown head gasket on my 99 si, b16a2. I pulled the head and sent it out to a machine shop, we reinstalled the head and the car ran perfect for 5 days. All of a sudden i stopped to get gas and the car wouldn't restart. I towed the car to my shop and the next morning I tried to start it and it fired right up. But it was smoking really bad out the tail pipe. shut it off and removed the spark plugs and found that the 2 middle pistons have a puddle of coolant on them. Thought maybe it was a bad gasket so we did the job again. after a new honda gasket and head bolts were installed a second time, we still have the same problem. used a straight edge and checked the block and the head, and they are both straight, no warping. what else could be causing the coolant and oil to mix? the coolant and oil did not start mixing until the head was machined. changed the head gasket due to external oil leak.
Old Feb 7, 2013 | 05:23 PM
OBRJosh's Avatar
Default Re: 99 civic si head gasket problem
engine stock?
Old Feb 7, 2013 | 06:07 PM
hybridmiklo's Avatar
Did you deck the block to make sure its not warped as well?
Old Feb 8, 2013 | 07:12 AM
MHM2008's Avatar
Stock motor, and yes i checked the block and it is not warped.
Old Feb 10, 2013 | 09:41 AM
DC5STAR's Avatar
Did the car ever overheat really bad with the blown head gasket? if so a water jacket could have busted or cracked, letting coolant into the oil.
Old Feb 10, 2013 | 11:47 AM
Runnerdown's Avatar
If you didn't replace the dowel pins there is a chance that they could be causing the head to not seat correctly. Sad part is that the original gasket was probably fine and something else was causing the leak. I see that all the time.
Old Mar 13, 2013 | 07:33 AM
MHM2008's Avatar
So i have now removed the block and sent it to the machine shop they decked the block, pressure tested the block, honed and changed the main bearings, and new rings. I got the engine all back together and i am still having the same problem. I am getting coolant on the top off #2 & #3 pistons. I am ready to blow up the car, PLEASE HELP. ANY IDEAS
Old Mar 13, 2013 | 07:50 AM
kyden's Avatar
did they check for cracks in the head?
Old Mar 13, 2013 | 08:19 AM
MHM2008's Avatar
Yes. The head was pressure tested and it was good. The block was pressure tested and it was good. Head and block were decked. The oil and coolant never mixed and i had no coolant on the pistons until i sent out the head to the machine shop.
Old Mar 13, 2013 | 11:58 AM
Scottchy014's Avatar
What about checking any other entry points for coolant leaks. I'm not too familiar with B-series but check to see if the coolant that passes through the throttle body isn't leaking by. #2 and #3 pistons would catch the coolant first. I may be totally out there but I'm trying to think outside the box since you may have disturbed so many things in your engine bay.
Posted from Honda-tech.com App for Android
1998GsRIntegra's Avatar
Are you installing the head gasket upside down by any chance?
Old Mar 13, 2013 | 01:17 PM
grumblemarc's Avatar
The Grumpiest
Is that possible?
Old Mar 13, 2013 | 06:26 PM
Originally Posted by grumblemarc
Is that possible?
Yes, I've seen it more than just a handful of times. Even though the head gaskets have "up" stamped into them, people still put them on upside down.
Old Mar 14, 2013 | 08:28 AM
MHM2008's Avatar
Finally fixed the problem. It was the coolant that goes through the throttle body. i by-passed the throttle body and the problem is gone. Finally the car runs great. Thank you everyone for the input.
Now time for the Skunk2 pro series ITM
and the Skunk2 Alpha series 70mm throttle body
Old Mar 14, 2013 | 10:26 AM
No problem at all. Good luck.
VAryda
Jul 20, 2016 10:30 PM
flozella
Aug 30, 2014 07:20 PM
slipyoke
Jun 17, 2012 07:22 PM
lexluther
16
Jan 4, 2010 09:51 AM
88 EF Hatch
Jul 11, 2009 08:46 AM
