94 Honda Automatic Options
I have already replaced the auto in my 94 Accord twice, so I am thinking ahead in case I have to replace it again. I see the the trans out of a Gen 5 wagon has a slightly lower final gear ration than my sedan and should swap OK. But I also see that the trans from a 95-98 Odyssey has even lower gears, in 4th and the final ratio as well. Is it the same trans and will it interchange?
I thought the Odyssey trans would bolt up, but I wondered if it was all electronic like the 98-up Accords. I hadn't thought about the Preludes. Definitely an option.
First gen 95-97 Odys will interchange. Replaced the blown AT in the '95 EX with a Ody unit. I was pleasantly surprised at its new found quickness. Your highway rpms will be higher for the same speed.
I travel a stretch of interstate with a very steep grade. My EX won't pull it in 4th, so I am thinking the Odyssey trans would be just the thing. Also, slowing me down a little on the interstate might be a good thing too.
stallinrawlings
Transmission & Drivetrain
Mar 8, 2013 03:57 AM
