1996 Ek Hatch Problems
Two things are not working. Recently added fog lights into my car and a couple days after the installation my turn signals now do not work. Also prior to the installation of the fogs my tach meter will come on sometimes but does not always work. It will randomly start working after driving for a bit but it isnt always on the correct rpm. Help please!
So the fogs are still working but the turn signals arent? Did you wire the fogs to the turn signals? Did you check for any blow fuses? Did you mess with the turn signal grounds while installing the fog lights?
For the tach...check the wiring inside the dizzy or the cluster is going bad.
I ran the power through my radio because it is an easy way to tell if it has power or not. The fogs work all my lights work it is just the turn signals wont work. I havent had the time to check the fuse yet bout to do it though.
I am not good with all of the wiring things so this is why im having a lot of troubles. Plus I dont want to like eff my whole car up.
Jonnyr4c
Nov 27, 2005 09:02 AM
kreush33
Jun 14, 2005 04:29 PM
