Honda CR-V & Element 2WD & 4WD Element & CR-V
Gen 1 Trunk Pop Fuse?
Old Feb 6, 2013 | 03:03 PM
SirFerret's Avatar
Icon2 Gen 1 Trunk Pop Fuse?
I Was trying to get my Viper alarm aux button to pop the rear glass. Figured out how to do it, but realized that I am going to need a relay . The alarm gives a negative signal when the aux button is pressed so I thought "Hey I bet I could test if it would work with a negative to the battery!" Wrong. Touched the positive trunk wire to the negative battery wire to complete the circuit and got a little spark. Now there is no longer a 12 volt drop across the trunk button, so I am assuming I blew a fuse somewhere. Everything else in that car works, and I can't see a fuse for the trunk release in the cabin fuse box. Where is the fuse that controls the trunk release button? Or did I burn something out that will take a bit more effort to fix ?
Thanks so much!
TLDR: Where is the fuse that controls the trunk release button?
Old Feb 6, 2013 | 03:46 PM
SirFerret's Avatar
Default Re: Gen 1 Trunk Pop Fuse?
Found the solution if anybody else is curious. It is fuse #10 (according to the manual) in the under the hood fuse box. Melted the 20amp fuse pretty good!
dhealey
11
Jun 5, 2024 06:31 PM
Crocky
Apr 19, 2017 11:03 AM
b18Aaron
May 4, 2010 08:49 PM
IMPACT
Audio / Security / Video
Mar 2, 2006 11:06 AM
4doorH22
Nov 27, 2001 09:48 AM
