Stereo&Alarm Issue ! Please Help !
Old Feb 27, 2006 | 05:05 AM
IMPACT's Avatar
Default Stereo&Alarm Issue ! Please Help !
Hey guys, here is the scoop. My battery bit the dust, so I replaced it. And I jumped into the car, and turned her over. Woohoo! Wait, no dash clock or stereo working! Grrr, so I crawled down and checked the fuse panel. The fuse isn't burnt. WTF ! I have no idea why its not working. I closed the door and tried to arm the car, nope! Didn't work either, no I'm pissed. What gives?
Its a 95 Integra LS. Up until I had to replace the battery everything was working fine. Now, its not! Hoping some out there has some insight into the issue.
Thanks in advance.
Old Feb 27, 2006 | 07:03 AM
B18C_EJ8's Avatar
Have you checked all of the fuses in both fuse boxes and the fuses on the alarm??
Old Feb 27, 2006 | 12:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
Ditto the above, 7.5A fuse in under hood fuse box. 94
Old Feb 27, 2006 | 12:48 PM
IMPACT's Avatar
Default Re: (fcm)
Right on, I was losing it. Hopefully your right, that would make things so much better for me.
Thanks again
Old Mar 2, 2006 | 06:46 AM
IMPACT's Avatar
Default Re: (IMPACT)
So this is still a problem. No stereo, no alarm. I'm not too sure which 7.5amp fuse under the hood your refering to? Does anyone else have some info on this situation. I like to listen to the radio, and I really would like to have the alarm working too. Please help me!
Old Mar 2, 2006 | 07:56 AM
fcm's Avatar
fcm
Old Fart
The 7.5A fuse is the constant power backup power fuse for the radio, on a 94 LS it is fuse 11 in under hood fuse box and in the 94 it is the only 7.5A in the under hood fuse box. 94
Old Mar 2, 2006 | 07:58 AM
IMPACT's Avatar
Default Re: (fcm)
And what if thats not it? I have a 95 LS. I'm going to check anyways, but if its not that? Whats the next step?
Old Mar 2, 2006 | 08:16 AM
B18C_EJ8's Avatar
Check the fuse first. Then we'll talk.
Old Mar 2, 2006 | 09:17 AM
IMPACT's Avatar
Right on! It worked, geez sometimes I don't even think. Thanks for all the help guys.
Old Mar 2, 2006 | 11:06 AM
fcm's Avatar
fcm
Old Fart
Here is something else to think about, the alarms power should not be hooked up to that circuit, it is only 7.5A and it is memory for the radio and the ECU and power for the clock. power for the alarm should be connected directly to batt. or the main power buss on the fuse box, [under dash fuse box] or even the 12V constant going to the ign. switch.
And no you can not put a bigger fuse in place of the 7.5A one 94
SirFerret
Honda CR-V & Element
Feb 6, 2013 03:46 PM
97civicB18C
Audio / Security / Video
28
Oct 8, 2006 01:39 PM
ahloung
12
Mar 16, 2006 08:00 PM
Jmorin
Sep 24, 2003 09:55 AM
AssPenny
Jan 7, 2002 09:29 AM
