who owns this hatch?
http://community.webshots.com/user/robertrtyper
don't know his h-t user's name. i need to ask him about OBD2 wiring particularly the gas tank/fuel pump/fuel pressure assembly unit.
I think maybe this is what you are looking for.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Next time use this
https://honda-tech.com/zerosearch
That page works wonders.
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Next time use this
trooper0641
Apr 20, 2004 07:28 AM
skribblah
12
Sep 15, 2003 09:30 AM
