No dash lights and shifter lock will not disengage
Old Feb 5, 2013 | 06:27 PM
Open Road's Avatar
Default No dash lights and shifter lock will not disengage
It's a 94 civic hatch. This car was thrown together in a hurry. We have checked for bad connections or loose grounds and haven't come up with anything. When we first got the car going the dash lights worked but were very dim. Now none of the lights other than indicator lights(oil, battery, etc) will work. The drive reverse neutral d4 etc all light up but only when you hit the brake pedal. When you hit the brakes the lights light up on the shifter too but go out when you let off the brake. Then sometimes they won't come on at all. Also the shifter lock is not disengaging when the brake is applied.
I absolutely hate wiring issues. I wanted to check here in hopes that someone can say "yes this is your problem" if not we will go back to fishing for problems. Thanks in advance
Old Feb 5, 2013 | 09:34 PM
TCE_4BangN's Avatar
Default Re: No dash lights and shifter lock will not disengage
Seems like your problem is definitely wiring. Sounds like you have a pinched wire some where, or a bare with grounding out some place. Maybe off the brake? Thats what I'd check first.
Old Feb 6, 2013 | 05:47 AM
fcm's Avatar
fcm
Old Fart
I would look at grounding, when one circuit, [brakes] have an effect on another circuit, [gear position indicator lights] it is almost always due to a grounding problem. 94
Patrick Jordan
Aug 27, 2012 08:10 PM
pleej
Oct 29, 2009 10:17 AM
bluelxfodo
Jun 4, 2007 05:58 AM
jolt-tsp
Jul 12, 2006 05:07 AM
puppetmstr80
Aug 26, 2005 11:43 PM
