'98 Dx Intsrument lights not working???
Old Feb 5, 2013 | 05:02 PM
Mitch965's Avatar
Icon2 '98 Dx Intsrument lights not working???
My Instrument lights and Fog lights are not working. Headlights are still working. I tore apart the cluster and checked all the wires and everything seems to be secure. I took off the fuse box cover under the steering wheel and i see that there is a fuse for the instrument lights there too, i will try replacing that tomorrow but i highly doubt that's what it is besides that can anyone think of what the problem could be?
Old Feb 5, 2013 | 07:57 PM
Former User's Avatar
Default Re: '98 Dx Intsrument lights not working???
Why do you doubt that dash fuse 30 is blown? That's the first thing to check. Click the test fuses link in my signature.
If the fuse is fine, then next test the light switch.
Old Feb 6, 2013 | 11:48 AM
Mitch965's Avatar
Ok i put a new fuse in and still nothing..what did u mean check the light switch?
Old Feb 6, 2013 | 11:52 AM
If the fuse blows quickly after you install it then you are being falsely led to believe the fuse is good. Voltage test it.
Old Feb 6, 2013 | 11:54 AM
Mitch965's Avatar
I put a whole new fuse in and nothing came on. I read your fuse test thread but dont quite understand it. Im sorry. Im a complete newb.
Old Feb 6, 2013 | 11:55 AM
What didn't you understand? Be specific.
Old Feb 6, 2013 | 11:57 AM
Mitch965's Avatar
How exactly do you measure the voltage?
Old Feb 6, 2013 | 11:59 AM
Mitch965's Avatar
I see the test tabs
Old Feb 6, 2013 | 12:00 PM
Do you have access to a multimeter?
I see the test tabs
Good.
Old Feb 6, 2013 | 12:02 PM
Mitch965's Avatar
No i dont.
No i dont.
Well, you need one...or at least a test light.
Old Feb 6, 2013 | 12:05 PM
Mitch965's Avatar
Hmm, ok, what i dontundrrstand i guess is if i put a brand new fuse in than and nothing comes on wouldnt the problem be elsewhere?
Old Feb 6, 2013 | 12:11 PM
The fuse could blow immediately after turning the light switch on.
The voltage test also tells you whether the light switch delivers voltage to the fuse.
You can buy a $4 digital multimeter from Harbor Freight Tools.
Old Feb 6, 2013 | 12:12 PM
Mitch965's Avatar
Ahh i see. So you are actually testig the fuse while it is plugged into the fuse box?
Old Feb 6, 2013 | 12:13 PM
Correct
Old Feb 6, 2013 | 12:15 PM
Mitch965's Avatar
..hm alright well thank you for your help and speedy replies i greatly appreciate t.
Old Feb 6, 2013 | 12:17 PM
Do the voltage tests on fuse 30 with the light switch turned on to the parking lights setting.
S33
Dec 27, 2014 10:22 AM
[Ennis_D]
Feb 8, 2013 06:40 PM
byc_cb7
Sep 28, 2009 02:45 PM
gsrcivic619
Mar 23, 2006 10:53 AM
caspers_hatch
May 24, 2005 09:49 AM
