air boost valve & turbo
Old Feb 4, 2013 | 11:25 PM
balbowskie's Avatar
Icon2 air boost valve & turbo
What does the air boost valve do exactly? And if i intend on boosting my engine should i remove and block it off with a block off plate.
Old Feb 5, 2013 | 06:51 AM
jdm_phunk's Avatar
Default Re: air boost valve & turbo
Has a vacuum line that attaches to the air intake before the throttle body. It is responsible for adding additional air to the engine during colder temperatures
Old Feb 5, 2013 | 10:06 AM
balbowskie's Avatar
Should it be blocked off when adding a turbo setup?
Old Feb 5, 2013 | 10:12 AM
xenocron's Avatar
Man I havent worked on an OBD0 intake manifold in years, but I believe its there to soften the throttle closing when quickly letting off the throttle.
Fast idle valve under the TB is for cold temp air bypass.
Old Feb 5, 2013 | 02:53 PM
GhostAccord's Avatar
The air boost valve is only used during startup. To be honest if you are boosting you would be better off just removing it and blocking it off.
OBD1 90-93 F22 Accords still used this as well.
Old Feb 5, 2013 | 03:51 PM
balbowskie's Avatar
Mine is 93 prelude uses this h23a1 odb1
Old Feb 5, 2013 | 03:59 PM
Yeah the OBD1 SOHC Prelude would have one as well.
Old Feb 5, 2013 | 04:54 PM
balbowskie's Avatar
Since it seems it could be more of a weak point than anything else i will be removing it and blocking it off. Unless someone has a reason why i should keep it around under boost situations....
Old Feb 5, 2013 | 05:04 PM
If, for some reason, you do decide to keep it. It would be best to place the hose barb for it, in the tubing on the inlet side of your turbo.
Not the boost side...
Old Feb 5, 2013 | 07:54 PM
balbowskie's Avatar
Good point, fine sir! Could i just draw from atmosphere also, if i was to say keep it...? Thanks for some fine discussion here!
Old Feb 6, 2013 | 11:42 AM
You could, however it would be unfiltered..... If that matters to you, then you could run a small vent filter on it. If it doesn't matter then leave it open to the engine bay/atmosphere.
builthatch
Jan 2, 2009 02:55 AM
komat
Apr 8, 2007 01:02 PM
hks_Racing
Oct 12, 2006 10:07 PM
xxmastermindxx
Aug 26, 2006 05:48 PM
